Restores the default primary VMAN ethertype value of 0x88A8 or deletes the secondary ethertype value.
| secondary | Deletes the secondary ethertype value. |
If the secondary option is not specified, it restores the default primary VMAN ethertype value of 0x88a8.
When you enter this command without the secondary option, the primary VMAN ethertype returns to the default value of 0x88A8. If you specify the secondary option, the secondary VMAN ethertype value is deleted (no value is assigned).
Before unconfiguring the secondary VMAN ethertype, any secondary VMAN port must be changed to the primary VMAN ethertype; otherwise the command fails.The following example restores the primary VMAN ethertype to the default value:
unconfigure vman ethertype
The following example deletes the secondary VMAN ethertype:
unconfigure vman ethertype secondary
This command was first available in ExtremeXOS 11.0.
